sputter and misfires
Old Jun 29, 2014 | 04:26 AM
ice_man0617's Avatar
Car: 89 Camaro RS
Engine: 3.2L V6
Transmission: 700R4 mega monster
Axle/Gears: Auburn LSD/3.73 Richmonds
ok well the maro started backfire/missing last saturday but rpm were sporadic....thought maybe it was the ignition coil...no dice coil is stool good because it starts without any problem...thought maybe fuel pump...floored the **** out of it when it wasn't sputtering no problem....it started to miss while idle a couple days ago.....thought maybe it could be MAF unplugged and no dice...so finally thought about sporadic rpm....pulled EST wire OMG no more rpm jumping and sporadicness....so...my question is am I right to believe that this is dealing with the damn ECM! is it going out?
Old Jun 29, 2014 | 10:24 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Go get your ignition control module tested. Or just replace it.
Old Jun 29, 2014 | 04:37 PM
Car: 89 Camaro RS
Engine: 3.2L V6
Re: sputter and misfires
well I change the entire distributor and no dice...still does it and now I'm having cranking issues...could be because the engine is hot and the pistons are expanded...cuz it's being a straight pita right now...so going to let the car sit and kool so I can set the timing...it won't stay running long enough to set it while its hot! so yeah...icm is a bust so fasteddie if you could chime in do you think i'm right about the computer being a gonner
Old Jun 30, 2014 | 04:22 PM
willexoIX's Avatar
I'd still get the ICM tested. Just cause its new don't mean it ain't broke. ICMs tend to be somewhat fragile, if the box was dropped at any time it could be a gonner. I installed a brand new cardone dizzy in my car and the rotor phasing was wrong out of the box. Plus the rotor was crap and the strap was too short. I had to make a Frankenstein rotor to make it work. Swapped the old strap to the new rotor.
db057
Jan 10, 2020 08:55 PM
db057
Apr 28, 2019 07:45 AM
NZKnight
Oct 15, 2015 02:47 PM
camarohelp
Sep 22, 2015 03:19 PM
Jk_Under
Sep 8, 2015 08:13 AM
