Coolant leak near oil pan 3.1l
Old Jul 14, 2014 | 09:12 AM
Rell_1218's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Axle/Gears: Stock
For the past 3 days or so I've notice coolant underneath the car after parking it for the night. My car isn't running hot and the coolant in the radiator isn't mixing with anything. What could be causing my coolant to leak?
Old Jul 14, 2014 | 09:56 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Coolant leak near oil pan 3.1l
Have you checked your lower radiator hose?
Old Jul 14, 2014 | 10:12 AM
Rell_1218's Avatar
Engine: V6 3.1L
Axle/Gears: Stock
Yes, there's no leakage in that area
Old Jul 14, 2014 | 12:45 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Freeze (core) plugs slowing leaking from rear of engine? Are you replenishing coolant yet? This is what happened to my 3.1 V6 until it became a flood.
Old Jul 14, 2014 | 03:05 PM
project89's Avatar
it can also leak out from the knock sensor as well or any of the small pipe plugs in the side of the block
Old Jul 14, 2014 | 04:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Front and center under the TB there is a funky port to pull (or put) coolant from the block. The OEM ones do not hold up, so if it hasn't been replaced yet it is a prime suspect.
Look under the car at where the coolant is on the ground. The location of it is helpful in locating the leak on the engine.
RBob.
Old Jul 14, 2014 | 08:21 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Need to grab a light and look around the block to find out where it's wet (when the engine is cold, obviously, otherwise the coolant will just evaporate). The leak could be in any of a thousand places from the heater core hoses to the water pump.
Old Jul 19, 2014 | 07:18 PM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Lower intake manifold gasket
Old Jul 21, 2014 | 05:21 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Get a pressure tester too, pressurize the system and start checking, top to bottom, front to back. Front of the engine is a common place; intake gasket, TB lines, waterpump, hoses. Where are you seeing the coolant at in relation to the engine?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
