ideling badly after engine repair
Old Jul 29, 2014 | 12:41 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
ok so i had to pull my motor to replace freeze plugs and now that i got it in after doing new ignition stuff plugs taylor wires msd coil cap and rotor etc it iddles horibly and started throwing code 43 i looked it up and everyone says its some how a knock sensor well my knock sensor is broken it wont stay in the socket because have the plastic shroud crumbled away so only one side grips the plug help please
Old Jul 29, 2014 | 05:07 PM
mikey8494's Avatar
Axle/Gears: stock
Re: ideling badly after engine repair
update i just broke the starter sylinoid off the starter when trying to crank it why is it doing this. am i saposed to reset the timing after i put a new cap rotor coil and wires on?
Reddeath210
Oct 6, 2015 08:20 AM
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
LittleFranks
Aug 20, 2015 03:55 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
