89 2.8 mpfi vac hose?
Old Aug 10, 2014 | 08:13 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Hey everyone..
Been pluggin away at the car in some spare time.. Got it runnin alot better still missing the vac controller. But may have a line on new ones.. (may)..
But my issue is the vac line that goes to the back of the intake manifold (passenger side) has been disconected and plugged with a screw..lol..not sure where it is supposed to go.. If some one can post a pic of there vac hose routeing it would be a huge help to me..cant figure out for the life of me where it goes to
Old Aug 11, 2014 | 10:21 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Originally Posted by Dutch420
Hey everyone..
Well one goes to the hvac panel. The other I cant quite remember at this point because mine dont run where they used to anymore. I think to the EGR vacuum switch. Im sure someone has a photo/diagram.
Also If I recall, there have been numerous threads here on the V6 boards asking the very same question.
Old Aug 20, 2014 | 04:25 PM
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
Re: 89 2.8 mpfi vac hose?
if you are talking about the vac's on the upper plenum, the passenger one goes to the hvac, the driver side (the big one) goes to the brake booster. The one that comes off of your actual lower intake manifold goes into a tree kind of thing that goes all over the place. When you look at the vac diagram, it doesn't include the two that are on the top of the upper plenum.
Old Aug 20, 2014 | 06:41 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Ok great thank u that helps a lot.. how do I test for proper vacuum
Old Aug 22, 2014 | 03:20 PM
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
vacuum gauge.
Old Aug 22, 2014 | 03:36 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Lol figured that.. ddid some research found I'm supposed to do it from the back of the plenum.
Old Aug 22, 2014 | 04:11 PM
willexoIX's Avatar
Just figured I would throw this up here for you. Don't know if it helps but its the factory vacuum diagram for the 2.8 on my hood.
Old Aug 22, 2014 | 04:45 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Thanks thats good info.. I put a new egr vac controler on not sure if its getting vac though
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
usafirebird
Sep 29, 2015 11:58 PM
