timing question
Old Sep 20, 2014 | 03:15 AM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
timing question
I was checking the timing the other. Had the tan wire unplugged and was getting 10 degees solid. When I revved it the timing moves about. Is that normal?
Old Sep 20, 2014 | 06:34 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: timing question
Yes. Iirc, even with the esc wire unhooked the icm will add in timing above certain rpm. As long as your at 10 degrees btdc at a warm idle, your timings set good.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
