Blue connector ID please
Old Sep 24, 2014 | 10:13 PM
Springster's Avatar
Car: 1986 Camaro Sport
Engine: 2.8L
Axle/Gears: Stock
1986 2.8L Next to the coolant sensor there is a blue connector with a wire clip around the lower section to help hold it on. The wires come out of a rubber strain relief. The wire colors are tan and pink, I think. Searched for an hour an could not find out what it is. I measure about 37 ohms on the sensor/sender what ever it is. Can someone ID it for me please? Thanks!
Old Sep 25, 2014 | 05:58 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Blue connector ID please
Picture?
Old Sep 25, 2014 | 07:37 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Originally Posted by fasteddi
Picture?
This, also what year car? Camaro or Firebird?
Old Sep 25, 2014 | 11:16 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Should be the connector for the cold start injector sensor. Looks like an injector connector. Having the wire around it kinda gave it away. The only things on a 2.8 with those style connectors are the injectors, cold start injector(I think), and the cold start injector sensor.
The cold start injector sensor is right next to the ecm coolant temp sensor located under the throttle body.
Old Sep 25, 2014 | 12:03 PM
Springster's Avatar
Engine: 2.8L
Axle/Gears: Stock
Thanks! That makes sense. I am troubleshooting a startup issue (in another thread (Varnished gas?)) and when I unplugged this sensor it did not fire at all. I thought I was on to something but it was just my cold start injector no longer squirting...
Thanks to all for responding,
Pat
Old Sep 25, 2014 | 12:16 PM
willexoIX's Avatar
Pat
Yea that could cause a no start with it unplugged. No problem Pat. Hope you get your car figured out!
Linson
Sep 21, 2015 01:08 PM
Tweeks25
Sep 17, 2015 08:04 AM
Ironhead38
Sep 7, 2015 02:26 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
