Need help with 3.1 Mods!!
Old Nov 26, 2014 | 09:23 PM
sc92's Avatar
I have a 1992 firebird 3.1 with an aftermarket intake, IAT sensor relocation and catalytic converter delete.These are the mods i was thinking of for this spring:
Delta 260 cam grind with new core, and lifters
COMP Cams Magnum Steel Roller Tip Rocker Arms
(1413-1)
1.52 lift(Has necessary Valve cover Clearance
New Timing chain set
New Springs
Is it really necessary to do a tune?
Am i missing anything?
i heard this is a pretty good setup in different threads.
Old Nov 27, 2014 | 06:20 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Need help with 3.1 Mods!!
Yes it is necessary to tune the car. If you don't tune it the car will run rich at idle and lean on the higher rpm area. And you wont gain the hp you could with those parts. This is because it's a speed density system. If it was a 2.8 maf system you could get away with it.
Old Dec 1, 2014 | 10:44 AM
ice_man0617's Avatar
Car: 89 Camaro RS
Engine: 3.2L V6
Transmission: 700R4 mega monster
Axle/Gears: Auburn LSD/3.73 Richmonds
still runs a little rich with the maf sensor too, trust me I'm dealing with that right now...Oh fast..I sent you a PM too! need your help with something
Elephantismo
Feb 13, 2019 12:51 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
cking99
Sep 22, 2015 11:33 AM
