Timing Question -- 3.1L to 3.4L Swap
Old Dec 7, 2014 | 10:47 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Not sure what to set the timing for the swap. Car is a 92 RS and just swapped the 3.1L to a 3.4L and used a new Comp Cam 252H. Any recommendation on the setting for the timing? This is my daily driver so the cam is supposed to be a little more power without too much loss of mileage according to a performance shop... Put in new lifters and pushrods.. Upgraded to new Comp Cam valve springs.. The 3.4L rockers and pivots were in great shape so used the originals... New stock distributor but no other performance changes.. I did use the 3.4L injectors and new 3.4L spark plugs as recommended in the swap doc's..
Thanks....
Old Dec 8, 2014 | 09:13 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Stock timing, or 10° BTDC. With the EST bypass unplugged.
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
92projectcamaro
Aug 6, 2015 01:20 PM
