1991 Camaro 3.1L: Won't Start
Old Dec 3, 2014 | 06:25 PM
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Hey guys,
As some of you know I was in a crash at the end of September with my camaro, since then I have been focus on getting the major components and fixing the radiator core support damage.
I went to move the car a week ago and it fired up right away. After about 10 seconds the car shut off. The engine won't fire now. It cranks over but won't catch. I have checked the distributor and there is no corrosion or moisture.
If it helps there was no engine damage in the crash, I actually drove the car home after.
What sort of problems could arise from sitting for basically 2 months?
Thank you in advance,
John
Old Dec 4, 2014 | 11:35 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 1991 Camaro 3.1L: Won't Start
Is the fuel pump running? Fuel pressure at the rail? Sparks? Checked injector fuses? Does it fire with starter fluid sprayed in throttle body? etc. etc.
Old Dec 4, 2014 | 02:43 PM
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Problem solved!
I decided to check back over the distributor again today. I noticed some corrosion that I must have missed yesterday. I also decided to check the inline fuse I reinstalled two weeks ago. I must have not tightened it down all the way. I turned the key over and it fired right up!
Old Dec 8, 2014 | 09:15 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Originally Posted by C2YT
Problem solved!
Awesome. Glad to hear it was an easy fix. Also glad to see what fixed it being posted. We need more of that on the forums.
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
