91 3.1 5 speed.
Old Dec 18, 2014 | 07:09 PM
Pearcy91CAMARO's Avatar
Car: 91 camaro rs
Engine: 3.1
Transmission: 5 speed
91 3.1 5 speed.
I've been working on my car for 3 weeks now. New parts include plug wires plugs cap and rotor. New computer new coil new fuel pump new injectors new fuel fikter. Had the car idling perfect but driving bad, I backed it in and went back to start it but nothing. Won't even pop. Fuel pump comes on and it has spark. Will fire up with starting fliud... Is there any chance that the icm is bad? Or something to do with the comouter? The vats is okay nothing wrong other. Please help I dont wanna see this car just sit and rot, thanks
Old Dec 18, 2014 | 07:16 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Try icm or pickup coil in bottom of dizzy ... if a 3.1 even has a dizzy ? Lol
Old Dec 19, 2014 | 07:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 91 3.1 5 speed.
Excuse my dumb post: {If the stock OEM injectors are still in the engine, replace them.}
I thought your name looked familiar, already have new(er) injectors. Since starting fluid sprayed into the intake will fire the engine. It has to be fueling.
VATs will do that, it stops the injectors from firing. A bad ICM can also do this, as the ECM doesn't see reference pulses from the distributor.
RBob.
Old Dec 19, 2014 | 10:20 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 91 3.1 5 speed.
Did you check or replace the Fuel Pressure Regulator (FPR). Didn't see it mentioned. Will cause symptoms like yours. Good Luck.
Old Dec 23, 2014 | 09:01 PM
Car: 91 camaro rs
Engine: 3.1
Re: 91 3.1 5 speed.
Runs perfect now, new distributor new fuel system new computer. No idea what it was but leaning to ICM
Old Dec 29, 2014 | 11:06 AM
Stewie's Avatar
Car: 1992 Firebird
Engine: 3.1L
Transmission: Manual T5
Axle/Gears: Stock
Re: 91 3.1 5 speed.
If you replaced the ICM when you installed the new dizzy, it probably was the ICM.
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
racereese
Oct 3, 2015 03:46 PM
cking99
Sep 22, 2015 11:33 AM
