2.8 timing chain replacement
Old Mar 28, 2015 | 07:35 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
so today I got a 82 Camaro in the shop that needs the timing chain replaced. now, not having done a 2.8 before , is there anything one should look out for? it SEEMS straight forward. however I have learned to not assume anything. do I have to drop the oil pan to get the front cover off? is there any special things to do with this one?
Old Mar 30, 2015 | 08:50 PM
bison999's Avatar
Car: 1984 Firebird S/E
Engine: 2.8 carbed
Transmission: Warner T5 5 Speed
Re: 2.8 timing chain replacement
Afaik no you don't need to remove the oil pan. However the timing gasket set should come with a small wedge that you have to replace, which happens to be where the cover mates with the pan. You will have to remove all the drive belts and accessories. Anyone correct me if I am wrong.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
86Base
Aug 8, 2015 01:34 PM
