3400 clarification?
Old Apr 24, 2015 | 07:29 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
3400 clarification?
So I just go to the salvage yard, pull a complete FWD 3400, the 185-HP version, then swap its pistons, heads, lower intake, and upper intake to my RWD 3.4 long block assembly? Which pushrods? Does the roller cam retrofit without aftermarket parts?
Which PCM? My '94, because of my 4L60E? Or is the 3400 PCM mandatory?
I accept some PCM retuning may prove unavoidable, I'd just prefer to minimize that aspect.
I'm really getting sick of not having all 6 firing anytime I go past half throttle, and I'm not willing to do more than spark plugs, again, for only 160 HP.
Thanks!
Old Apr 25, 2015 | 12:07 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 3400 clarification?
Pretty much. Use the FWD head gaskets if you use the FWD pistons as well, because of the quench height.
Which pushrods?
For best results, you get custom length.
No. While I know of one person that has a roller cam in a gen 1 block, it's not recommended to do this because of the different oiling needs between flat tappet and roller cams
Which PCM? My '94, because of my 4L60E? Or is the 3400 PCM mandatory? I accept some PCM retuning may prove unavoidable, I'd just prefer to minimize that aspect.
It would be easiest to retain your current ECM. I know there's some tuning software that will work with your PCM, but I'm not sure which one will.
Old Apr 25, 2015 | 07:26 AM
cosmick's Avatar
Good enough, thanks! I'm off to the salvage yards!
Nick McCardle
Sep 10, 2015 08:36 PM
LFN AT U
Jan 18, 2005 09:54 PM
Grumpy
24
Apr 30, 2004 08:36 PM
