Ford E59E-A2B injector
Old May 25, 2015 | 12:29 PM
Springster's Avatar
Car: 1986 Camaro Sport
Engine: 2.8L
Axle/Gears: Stock
I was going to switch to the F1ZE injectors on my 86 2.8L but found some Ford E59E-A2B. They are 14# according to http://www.fuelinjector.citymaker.co...low_Rates.html but at 30PSI (2 bar). So they are probably 19# at 43PSI? Anyone tried em or are they not the right size flow wise or physically?
Old May 26, 2015 | 08:10 PM
southbay08's Avatar
Re: Ford E59E-A2B injector
They are approx. 17lb....16.7 to be exact. They may be a tad too big for a 2.8 as replacements should be 15lb. You could always drop your pressure a bit to approx.
39-40psi if need be.
If we can help you, we have the 15lb bosch 4 spray injectors in stock. Hope this helps
Old Jun 14, 2015 | 07:56 PM
Springster's Avatar
Engine: 2.8L
Axle/Gears: Stock
UPDATE: I got the Ford injectors from South Bay and the 2.8 runs great now! Mark up another F1ZE success! Easy to switch out. Wires plug right on. About 1/4" shorter but if you use your clips from the stock injectors on the top groove it all fits fine and doesn't leak.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
