I need help...
Old Jun 21, 2015 | 10:31 PM
hunter91bird's Avatar
I need help...
I have a 1991 v6 bird. It starts but idles really rough. When the throttle is held open it doesn't Rev to a higher RPM. Any ideas...
Old Jun 22, 2015 | 08:21 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: I need help...
Fuel pressure comes to mind, followed by bad injectors and possibly a ruptured fuel pressure regulator diaphragm. Check your pressure on the rail. Should be in the low 40's I believe, if lower could be clogged fuel filter or failing fuel pump. Ohm your injectors, Should be between 13-14 range, my bad ones were 6 and 10. Disconnect vacuum hose from FPR, start engine and wait about a minute of two. If fuel comes dribbling out replace the FPR. Good luck.
Old Jun 23, 2015 | 05:52 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: I need help...
bad cat
Old Jul 26, 2015 | 11:45 PM
Bigboi's Avatar
Re: I need help...
Can I ask what fpr means
Old Jul 27, 2015 | 01:05 AM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: I need help...
Fuel pressure regulator.
Old Jul 28, 2015 | 11:56 PM
AussiePr0nCar's Avatar
Car: 1991 Camaro RS, 1991 Firebird
Engine: None, 3.1l LH0 V6
Transmission: None, 700R4
Axle/Gears: 3.42 Open, 3.23 Open
Re: I need help...
There's a good possibility that it could be the fuel pump. I've had this happen on my Firebird a few times, and I would always have to change the pump. Just make sure to get a fuel pressure gauge (Autozone or Harbor Freight), and sample the pressure as you try to run the car.
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
Kj Rockz
Jan 6, 2002 06:00 AM
Locry
Apr 29, 2001 12:09 PM
98_1LE
Mar 1, 2001 12:44 AM
