Return AC Delco 7mm spark plug wires or return for an 8mm set?
Old Jul 17, 2015 | 11:45 AM
darren8642's Avatar
I need to change my spark plug wires because while replacing the distributor cap I found one of the wires corroded . I bought the AC Delco 9706n spark plug wires and when I got them in the wires were labeled 7mm. I read here that I should shoot for 8mm wires but I didn't know which one to choose for my 2.8l so I decided to just get OEM not knowing what size they were.
Should I return these (I bought them from Amazon) and look for a different set or should I just use the set? I'm running ac Delco plugs and distributor cap.
Old Jul 17, 2015 | 03:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Return AC Delco 7mm spark plug wires or return for an 8mm set?
Check the 'made in xxx' country, if USA, EU, or Canada, use them. Elsewhere, find a set based on the above. If the OEM spark plug wire holders are still in place that too is a consideration.
A larger then stock wire may not fit.
RBob.
Old Jul 17, 2015 | 08:21 PM
darren8642's Avatar
The box says Assembled in Mexico so I guess that's a no go.
Old Jul 18, 2015 | 06:35 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
best deals ive always found was on ebay, find a uni fit set of spirial core wires for a V8, they come with both furd n GM ends, youll need a coil wire so youll only have 1 wire left when done but often way way cheaper then direct fit set of less quality wires.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
djmarch
Aug 9, 2015 05:27 PM
