87 2.8 Fuel Pressure Bleed Off Rate?
Old Jul 28, 2015 | 12:21 PM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
How long should it take for the fuel pressure to bleed down?
Mine primes to 41psi, but it bleeds down to about 30psi in 10 minutes.
I tried clamping off both lines, but maybe I didn't pinch them hard enough (didn't want to wreck them).
Injectors are refurb from southbay. Did the same thing with the old injectors. I'm wondering if it is the cold start injector. What could I plug that line off with to rule that out?
Old Aug 3, 2015 | 08:02 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 87 2.8 Fuel Pressure Bleed Off Rate?
GM spec is under 1 PSI lost in 20 minutes. Remove vacuum line from FPR to confirm it's not leaking.
Old Aug 4, 2015 | 10:06 AM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
Great, much appreciated.
I tried the test again and re-screwed on the gauge tighter. Seems to hold pressure now.
Thanks,
Rhys
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
