I'm stumped
Old Aug 1, 2015 | 11:46 PM
Bigboi's Avatar
I'm stumped
Car will start idle and die. It is getting 44psI to the fuel rail at idle when I put carb an choke down the intake it used to be where I could unplug the alternator and run fine but it wen back to none at all I'm so lost...
Old Aug 4, 2015 | 09:52 PM
Bigboi's Avatar
Re: I'm stumped
Really no one knows ��
Old Aug 4, 2015 | 11:03 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: I'm stumped
I'm sorry, I read your post several times, but I have no idea what you are trying to say
Old Aug 5, 2015 | 09:34 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: I'm stumped
Give details about the engine and more on what happens after starting and the symptoms it shows when it dies. Not sure what the connection is with the alternator.
Old Aug 5, 2015 | 07:05 PM
Bigboi's Avatar
Re: I'm stumped
Okay I was driving down the highway and the motor shut off I let it sit a few hours and drove it home thinking the issue was vapor lock . went to drive to orilies the car shut off . I had to tow it home. I could keep the car running at 500 rpm with carb and choke . tested the fuel pressure at the fuel rail it was getting 45psi when I had it idling at 500 rpm . then I tested with a diod light to see if the injectors were getting proper signals. They were. I had recently replaced the alternator so I unplugged it to see what it would do and it idled perfect. In any gear. Now it is back to only running with carb and choke in the intake
Old Aug 5, 2015 | 07:06 PM
Bigboi's Avatar
Re: I'm stumped
Oh sorry its a 92 3.1 v6 200k miles
Old Aug 5, 2015 | 07:53 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Re: I'm stumped
Ok... I am confused.. You have an oxymoron. Carb and Injectors. Which is it?
Old Aug 5, 2015 | 08:39 PM
Bigboi's Avatar
Re: I'm stumped
I have to use carb and choke cleaner to keep it running as sspray in the intake and I tested the injectors how is it an oxymoron...
Old Aug 5, 2015 | 09:36 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Re: I'm stumped
Ohhhh... "Cleaner". That word would have helped immensely a few posts ago.
But anyway... eventhough the injectors are testing good, the problem seems to lie in the fuel delivery.just because the injectors are ohming out properly, does not mean they are spraying properly.
Old Aug 5, 2015 | 11:04 PM
Bigboi's Avatar
Re: I'm stumped
Sorry!!! Is there any way to do that without pulling each one
Old Aug 6, 2015 | 08:51 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: I'm stumped
You need to test the injector resistance to start with. They should all be close to 13ohms or so. If any aren't then youj need a new set. Also, have you checked/cleaned the idle air control valve etc. etc. By the way, when you get to the injectors to test them also check the fuel pressure relief valve vacuum line for any gas smell. If you smell gas in the line replace the FPR diaphragm. Probably should do it anyway if it's original.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
