2.8 Charcoal Canister Delete?
Old Oct 24, 2015 | 03:18 AM
knightinblackar's Avatar
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
Hey guys and gals,
I'm mid through a full restoration on a 2.8 V6 'bird and I've hit a snag. The charcoal canister is toast. It's absolute trash. Every component is non functional or rotten and I can't get the bits here cheaply enough to warrant its rebuild (UK).
Will I have any running issues if I simply block the evap line and use a vented gas cap? Or use a vented gas cap with a fuel filter on the end of the evap line? I need 'from experience' answers not opinions on this one please.
Your help is greatly appreciated. Many thanks.
Rich
Old Oct 24, 2015 | 11:19 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: 2.8 Charcoal Canister Delete?
I pulled it once before I did my V8 swap. My car ran fine, but an 85 is much different than a 89.
Old Oct 25, 2015 | 02:58 AM
I was under the impression that aside from the serpentine setup and MPFI V6 was pretty much the same right through until the 3.1 was introduced. It's the same strengthened crank and components as the 89 I had!!!
How did u remove it? Did u cap the like or vent it?
Old Dec 15, 2015 | 08:15 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
I just took mine out and plugged. Had no issues like this .
86maro_252
Oct 10, 2015 06:52 PM
maxpower
Nov 28, 2002 09:45 PM
Gunny Highway
Oct 18, 2002 08:24 PM
FiReBReTHa
Jan 10, 2002 10:55 AM
86BIRD-MY FIRST CAR
Oct 31, 2001 03:39 PM
