v6 and the wonderbar
Old Oct 27, 2015 | 12:41 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I seem to recall reading about some fitment issues with the wonder bar and the lower radiator hose of a v6. Can't seem to find it in a search though. Anyone have any info on which ones fit and which ones have issues?
Old Oct 27, 2015 | 11:02 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Re: v6 and the wonderbar
Will need to check my car but I vaguely remember having to move the hose to get it to fit. Wasn't a big issue.
Pulled mine from a z28
Old Oct 27, 2015 | 11:48 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Depends on year IIRC. On my 89 with the 2.8 it sat on the bar and was smashed some. Since the 3.1s use the same rad as the V8 you shouldn't have a problem.
If you're near Orlando you're welcome to test fit mine on your car.
Old Oct 28, 2015 | 06:02 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I put on the TDS bar and yes the hose had to be pushed up a little but it's flexible and was easy to do. Not really an issue.
Old Oct 28, 2015 | 01:40 PM
Car: 91 Camaro
Cool. Thanks everyone. Guess I need to change my location on here... I live in TN now.
Old Oct 28, 2015 | 01:58 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
IIRC, you may also have a sharp edge against the hose so you may have to grind that down. I didn't see any way to move the hose on mine.
Old Oct 28, 2015 | 04:43 PM
ThirdGen1984's Avatar
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
Sorry if this sounds dumb, but it a wonder bar just a sway bar for the front end?
Old Oct 28, 2015 | 05:20 PM
Scorpner's Avatar
Engine: V6, V8
No, the wonderbar is a brace to help keep the front structure more stable and to avoid cracking near the steering box.
Old Oct 28, 2015 | 06:48 PM
Engine: LC1 V6 2.8L
Are wonder bars a good thing to have? If so how much do they run and could i get one for my 84' F41 2.8l V6
Old Oct 28, 2015 | 08:38 PM
Scorpner's Avatar
Engine: V6, V8
Yes. You can find them used on the classifieds here, Craigslist, or Facebook. New, they can be had at most any place that sells Thirdgen suspension parts. You will have to check around for prices, I'm sure that they would fit any Thirdgen.
Old Oct 28, 2015 | 08:46 PM
project89's Avatar
just cut the hose a lil short on the water pump side , this make the hose sit higher and it doesnt rub the wonder bar as bad
Old Oct 29, 2015 | 02:30 AM
Scorpner's Avatar
Engine: V6, V8
Ahh, ok that would help. I'll give it a try.
Old Oct 29, 2015 | 08:26 AM
J-money's Avatar
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
I believe I got my UMI wonderbar from summit earlier this year for $60. Took maybe 15 minutes in the dark to install with 2 people.
Fabi
European Region
Nov 3, 2015 03:32 PM
L98GTA87
Oct 29, 2015 07:45 PM
LiquidBlue
Oct 27, 2015 12:44 AM
Stank Bait
Oct 26, 2015 09:48 PM
Alex Fields
Oct 26, 2015 05:16 PM
