How do you change a pitman arm ?
Old Dec 21, 2001 | 08:09 PM
WaynesRS's Avatar
? thanx guys , Wayne
Old Dec 21, 2001 | 09:40 PM
I Cant Drive 55's Avatar
I know to remove the pitman arm from the steering box you have to remove the nut and washer from the shaft . make sure you mark everything so the new one goes back the way the old one came . Then you use a pitman arm puller , most nation wide (Pep Boys and etc. ) parts store chains rent them out , If not some gear pullers will work , but be sure not to mees up your threads.
On the other end a tie rod end separater should work.
Ghettobird52
Apr 21, 2020 08:44 PM
deracer
Apr 11, 2016 12:04 AM
zayne0
Aug 24, 2015 07:22 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
