3.1L LHO V6 Setting Idle
Old Mar 21, 2016 | 07:12 PM
inkscape's Avatar
Car: '91 Chevy Camaro RS
Engine: 3.1L LHO V6
Transmission: Borg Warner T5
Axle/Gears: GU6 3.42 Open Diff
So, the car used to idle like ****. Fixed a rough idle. Now the lowest I could get the idle was to 900rpms (This is a reading from a aftermarket Equus tach since the stock dash tach has bad readings since it's a 91). Manual says it's supposed to idle at about 675-700rpms. What are things I can get it that low if it really is supposed to idle that low when warm?
Replaced IAC, PCV Valve, Most vac lines since they were quite old cracking everywhere, Cleaned throttle body, replaced FPR Diaphragm since it used to dump fuel into the vac lines, new spark plug wire set, ran Seafoam through the engine via Brake Booster vac line.
(May have missed a few there. Memory a little horrible atm.)
Old Mar 22, 2016 | 11:37 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 3.1L LHO V6 Setting Idle
You haven't mentioned the injectors. If they are original they almost certainly need to be replaced. Then if it's still bad.....
Old Mar 22, 2016 | 12:05 PM
inkscape's Avatar
Engine: 3.1L LHO V6
According to the previous owner, he replaced them with the cheapest available option from a local parts store quite some time ago. About 2-4 years ago. (Autozone or O'Reilly's)
I just did a Minimum Air/Idle Speed set according to the tech article here of 450-500rpms with the set-timing disconnected as well as the IAC then went through the Idle Relearn process. Hovers a smooth 900-1000rpms while its warm in neutral.
Old Mar 23, 2016 | 08:52 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Have you checked for a vacuum leak all around the intake gastets? Are you sure the aftermarket tach is accurate?
Old Mar 23, 2016 | 11:04 AM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by ASE doc
When we install IAC valves, we do not "set pintle length" the IACV is a stepper motor. The ECM sets pintle length on its own. I would never try adjusting the IAC pintle length. Just install the new valve and preform the idle learn procedure. If you don't perform the procedure, the car will just tend to idle high until the ECM learns idle on its own. I also do not activate the IAC with it on the bench. I've seen others do it and Ive seen the pintle shoot across the shop, destroying the IACV. You can test the valve installed. The best tests are done using a voltmeter or test light and a scan tool.
Hi Inkscape , I have enclosed a quote from a guy who I believe may have an answer to your high idle . In my reading it appears that the 2.8 does not have an idle learn procedure , but that the 3.1 does need the idle learn procedure whenever the IAC has been removed .
Old Mar 23, 2016 | 04:00 PM
inkscape's Avatar
Engine: 3.1L LHO V6
I haven't checked for any vacuum leaks in the intake gaskets. The gasket between the upper and lower plenum are like brand new still.
But the gasket between the lower plenum and block for the intake, I am unsure of.
The tach, I'm sure is probably reading much better than my stock dash tach, but again I'm still unsure if it's 100% correct or close to.
From my reading about the idle relearn, basically running the engine until fan cycles once or a max of 10 mins, turn off for 5 seconds, then run the engine again for an additional 5 mins.
I'm not sure if it really needs to be driven for a few mins at freeway speeds though. Some things I read said it does and some said it doesn't.
Connor024
Aug 28, 2001 03:29 PM
v6-3.1
Apr 10, 2001 09:46 AM
v6-3.1
Apr 9, 2001 08:54 PM
Monkie
Oct 23, 2000 01:47 PM
Monkie
Sep 21, 2000 08:17 PM
