Unidentified Car Part, V6 3.1 - with Pic
Old Jul 19, 2016 | 04:04 PM
Donald Croes's Avatar
Car: FBody '91 V6 3.1
Hi all
Was working on my V6 todayand spotted that this tube was hanging lose by the passengerside firewall, near the distributorcap. I followed the cable and it disappears underneath the MAPsensor into a collection of cables. After that I can't seem to track it further. No it's not the vacuumhose for the MAP sensor, and it's not a sparkplugwire. It's about the size of a cap on a pen.
Anybody an idea what this could be?
Much appreciated
Old Jul 19, 2016 | 08:11 PM
TPI Sierra's Avatar
Car: 1989 GMC Sierra
Re: Unidentified Car Part, V6 3.1 - with Pic
Do your HVAC controls work? My guess it's to that.
Old Jul 19, 2016 | 08:43 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Old Jul 20, 2016 | 02:18 AM
Thanks!
My HVAC Controls work, sort of.
I can switch to different settings from Normal to Airco.
It blows air, but I actually have some issues with my HVAC
- When i have the blower on, no airco and temp. al the way in cold, the air blown out still feels 'warmish'
- My AC isn't working properly. The Compressor isn't working properly, but in the Netherlands it isn't always that hot
i'll fix that next year
But if this is part of the HVAC Controls, anybody an idea what it is? And where it goes?
Thanks!
Old Jul 20, 2016 | 06:18 AM
primergrey91rs's Avatar
Car: 91 Camaro RS
Engine: 3.1 v6
Originally Posted by Donald Croes
Thanks!
Thanks!
I believe it plugs into the heater control valve, which appears to have been removed
Old Jul 20, 2016 | 06:37 AM
Well, i think you have a point there
Just read this topic - https://www.thirdgen.org/forums/v6/6...rol-valve.html & read an other topic and it's all coming together.
First topic, one person describes he has bypassed the HCV with the knowledge he'll have slight warm air in the summer. I looked further and found an other topic with the actual cannister where the HCV should go on.
See the picture, can anybody tell me where it's located in the engine bay
Thanks!
Old Jul 21, 2016 | 06:56 AM
Re: Unidentified Car Part, V6 3.1 - with Pic - SOLVED
After some searching, I can conclude that the Valve has been removed
Oh well, that makes perfect sence why my cold-air blower always is a little bit warm
thanks all
Old Jul 21, 2016 | 10:53 AM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Plug it, anyways...
Old Jul 28, 2016 | 08:48 AM
Well, searched everywhere but there's no Valve to plug it in?! Atleast, i cant find it on my 3.1 V6. I'm gonna leave it for now. If anybody know where the valve normally should be, much appriciated
Old Jul 29, 2016 | 06:10 PM
project89's Avatar
passenger side of the engine twards the alternator, more then likley it has been bypassed and removed , due to the fact the plastic valve always breaks and causes u to loose all ur coolant , alls it does it stop warm/hot coolant from being sent threw the heater core when u have the selector set to cold.
iirc i dont even think u can get a new valve from the parts store anymore , and installing a used one is not a good idea because they get very brittle over the years from all the heat till they finally just crack and break
Old Jul 30, 2016 | 02:39 AM
Re: Unidentified Car Part, V6 3.1 - with Pic - Solved
Thanks!
With your directions I can confirm the valve has been Bypassed!
DelHell
Jun 10, 2008 11:27 PM
280Z28
Mar 27, 2003 02:49 AM
