1.6 roller rockers?
Old Dec 27, 2001 | 08:36 PM
V6camaroman's Avatar
1.6 roller rockers?
hey guys. got a question. i want to get a set of 1.6 roller rocker arms. i heard that comp cams makes them but i have never seen them. who makes 1.6 roller rockers for the 2.8. where can i get a set and how much. thanks.
Old Dec 27, 2001 | 09:14 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
As far as I know not one makes them for our car anymore(cheap enough that is)... But there was a guy on here not too long ago who put a set of V-8 1.6 in his 2.8L S-10 and they worked find and were cheaper at that. Heres the thread https://www.thirdgen.org/techbb2/sho...Roller+rockers
Old Dec 27, 2001 | 10:35 PM
DeadHero8's Avatar
jegs has them heres the link
http://www.jegs.com/cgi-bin/ncommerc...031&prmenbr=76
-Bruce
Old Dec 28, 2001 | 08:24 AM
thanks for your help
Old Dec 28, 2001 | 09:30 AM
syxx's Avatar
I did 1.6 rollers and I would never do it again unless at the same time you added new valve springs.. I think I was told 105# was the correct tension for that type of rocker. I just tossed on the 1.6's and the car runs slower because the other parts are so worn out because of age.
So if you do 1.6's and you have high miles get new valve springs at the same time otherwise it could be a mistake like mine.
Old Dec 28, 2001 | 10:57 AM
DeadHero8's Avatar
syxx makes a very good point on this one, you might even want to go just a little stiffer than stock
Old Dec 28, 2001 | 01:26 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Ya definentely do the valve springs. Also, crane makes full roller rockers for 349 dollars, and comp cams makes the magnum roller tip rockers for 130 dollars. Id personally go with the full rollers vs. the roller tip for less friction, more power, and an overall better product.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
