FS: 3.4L V6 fuel injectors
Old Dec 27, 2001 | 11:39 PM
Drew's Avatar
Hey guys, I've got a set of 3.4L V6 injectors to peddle.
they're 3.4L V6 fuel injectors, part number 17103509. According to Rich at Cruizen Performance, These injectors were used in 1991 thru 1993 on RPO LQ1 3.4L V6 engines with VIN code "X". Apparently they have a flowrate of about 17lb/hr. I bought them from a friend who used them for short time in a Z34 Lumina 3.4. New O-rings, all test 100% functional (proper resistence). Proved to be too much fuel for my stock Firebird 3.1. I've been told they'd be ideal for a nitrous setup on a 2.8 or 3.1L. These would probably clean up fine, they've jsut been in a ziploc bag in the back of the car for a few months. $80 +shipping.
They're gray even though they appear blue in the pic.
If anyones interested email me, I accept personal check and money orders. Items paid by check ship when the check clears, Money order items go out the same day.
Old Dec 28, 2001 | 01:25 PM
Drew's Avatar
Come on now, someones gotta have a cam or ported heads that can take advantage of a bit more fuel. The only problem I had was with the car maintaining and idle. Chances are now they'd work but I have a stripped fitting on the fuel lines to the fuel rail and it works the way it is, no desire to rip it apart again to try these.
Old Dec 28, 2001 | 01:53 PM
Camaro_hunter_d's Avatar
Those are the same poundage as the 3.1 stock injectors.(I think) Even so if your gonna get injectors you might as well get 19-20Lb ones and not 17's. Get more from it. The injectors I am looking at are Holly and are about $325 Not trying to flame at all just putting the info out.
Old Dec 28, 2001 | 03:55 PM
Drew's Avatar
If they were the same as stock 3.1L injectors they'd be the same part number. GM isn't going to use several different sets of identical injectors with different part numbers. Stock 3.1 injectors are said to be the same as stock 2.8 injectors which are 14 or 15lb injectors. Don't make guesses if you don't know, look it up or ask someone that does. I've done the research and have tested these injectors both with an ohm meter and in the engine and have determined that they're definitely more fuel than the stock 3.1L injectors deliver. Before setting the timing and fixing my exhaust leak my firebird would not idle with these injectors, it would run extremely rich till it died. Swapping back to the bad stock 3.1L injectors cured the idle problem and the car ran much better. If you want to add 19lb injectors to an almost stock 3.1 thats fine but unless everything is 100% optimum its going to be too much fuel. These injectors are a perfect step between stock and heavily modified, and I'm selling them less than a set of used stock injectors would cost. Like I've said the only reason I'm selling them is that I dont want to take the fuel lines out of the fuel rail again because the fitting is boogered up from some halfwit that worked on the car before I owned it.
Old Dec 29, 2001 | 02:04 PM
Drew's Avatar
I did some more research and ran some numbers thru the calculator today, and from the formula's I ran the stock injectors are only good to 137hp, these injectors thru the same formula should be good to 165hp. So for a mildly modded V6 these would probably work very well. 19lb injectors would be another 20hp.
Old Dec 30, 2001 | 12:24 PM
3.1 firebird's Avatar
How much does the 305 tpi injectors put out?
Old Dec 30, 2001 | 01:34 PM
Drew's Avatar
LB9 305 injectors are 19lbs, L98 350 are 22lbs, LT1 are 24lbs
Old Dec 31, 2001 | 01:34 PM
Drew's Avatar
Some more mystery for the puzzle... The Z34's are rated from GM at 210hp and 215lbs tq... So given this information the formula I used above doesn't match up. Not sure if GM was overrating the 3.4 in the Lumina or just running higher fuel pressure, or what... You make the call.
I've got a deal on some parts I need to close, so today only (dec 31st) I'm more than willing to bargain on my prices.
LarryD
Sep 19, 2017 09:34 AM
Baxbird89
Jun 30, 2015 03:51 PM
LarryD
Dec 30, 2014 05:59 PM
Keoki_Firebird89
Mar 10, 2002 11:50 AM
