engine lock cap reference
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: engine lock cap reference
while u are in there , do yourself a favor and replace the rear cam seal , and the rear main engine seal . not that u need to but it may save u form having to the pull the transmission again down the road
OK. Thanks for the reference. Good idea change the rear sales. Do you know the reference to buy them?. Sorry, but my English it's not good and it's dificult to me to look for the tech names and the sellers.
Then I will look for too, how to change these seals.
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
There is another p/n not sure the differences.
https://m.summitracing.com/parts/fel-bs40464/applications?prefilter=1
https://m.summitracing.com/parts/fel...ns?prefilter=1
so who knows
Transmission: 5-speed/T-5
For future reference those "caps" are called "Welch plugs" also commonly referred to a "frost plugs".
for exemple this ?
http://www.rockauto.com/es/moreinfo....251649&jsn=454
Engine: Lb9
Transmission: M20
Looks like a freeze plug/ oil galley plug kit.
Engine: Lb9
Transmission: M20
As long as they are listed for your vehicle you should be fine.
