How to upgrade alternator?
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
hey everyone. I have the little 97a alternator in my car and it's struggling when revs are low. Light dim etc. Is there a unit I can upgrade to which will fit? Mine isn't the serpentine setup.
Many thanks
Rich
Many thanks
Rich
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: How to upgrade alternator?
probably something wrong with the alternator-earlier GM Delco alternators often develop a bad connection where the stator leads are crimped into the rectifier terminals,resulting in weak low RPM output.This can easily be fixed by cleaning and then soldering the crimp connection.Could have bad diodes or other problem too.For an upgrade,CS 144 can be installed:almost the same design,same size and mounting as the 97A 17Si alternator,but better brusholders and soldered stator leads and an updated regulator.RollsRoyce and Bently have used the 17Si and the CS144 in the past
CS 144 is the way to go. Nearly bulletproof.
You might have to slightly modify your brackets though.
Or possibly rotate the housing so the charging lug is in the proper position.
Car: '82 z28
Engine: L83 5.7
Early model CS144 will be direct bolt on as long as the rear half is "clocked"to correct position-later CS144 is a little bulkier and might need some modification to fit.Either one will probably need pulley swapped.The early style cs144 was used ~3/86-1995 and IIRC,108 and 120a versions. later style was used ~1990-2000 and is 140 amps.
The later 140 amp version is a beast.
Thanks everyone. I'll look into this. How do you change the pulleys on them?
Use an air impact gun. You can just hold the fan directly behind the pulley (use a rag) and the impact is so fast it will spin the nut off before the rest has a chance to move.
When reinstalling, don't have the impact gun set to something like 500 ft/lbs!
Thanks for all the advice. Goig to try to track down a later cs144 as I'll need quite a bit of power for all the extra garbage on my car!
There are some 200A versions listed. Will they fit my application? Also does anyone have any details or links to ones they've actually installed on their cars so I can see how you've altered things?
thanks
what about this? Any good? http://m.ebay.com/itm/87-89-Pontiac-...%257Ciid%253A1
thanks
Transmission: 5-speed/T-5
You don't need a 200A alternator, not many people really do.
The biggest problem with a high output GM based alternator is poor low RPM charging output.
Even most high power stereo cars I've built didn't really need a 200A alternator.
Either go stock CS144, or 120/130A CS130. The CS130 is a small case alterator used on mid '80's to late '90's GM vehicles, and will be plenty. The CS144 has the benefit of a larger stator that makes for good low RPM charging capability and higher RPM charge stability. But the overall size is larger and can cause some fitment issues. My CS144 was a good upgrade on my old Sunbird.
I now use late model Toyota alternators for alternator upgrades, since they have AWESOME idle charge and usually no lower than about 100A rated, which seems to be under-rated.
Problem I have is that mine is a Knight Rider replica. So it has extra fogs, I've updated all the wiring and headlights, all other lights are LED, however the front scanner is 8x 55w halogen headlight bulbs and there's all the internal electronics to deal with. It's a lot of power to ask from an old 97a alternator that is supposed to handle all the cars existing functions.
What kind of power would you recommend running in the car?
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Somebody will jump on me as soon as I post this.
"All Mexican alternators are crap!!!"
Yeah. Whatever.
My factory-original Delco-Remy alternator on my 1988 V6 Sport Coupe died a dramatic death.
I bought a (Mexican) factory-new one from Autozone.
Driveability (less electrical system tomfoolery) of the car improved immediately.
So far, the Mexican alternator has been FINE.
Drop-in replacement.
http://www.autozone.com/batteries-st...82554_390890_0
You do not need a re-purposed hight-output alternator, or some custom alternator with enough output to drive two Patriot missile systems to power your V6 third gen Camaro.
Don't overlook the condition of your battery either.
If you have an old battery that was the cheapest battery the PO could find to get the car to run long enough to get rid of it, you might want to do the battery at the same time you do the alternator.
Yeah. Whatever.
I know I'm resurrecting an old thread but what are your thoughts on this? According to summit it will fit my car?
https://www.summitracing.com/int/par...d/submodel/s-e
Since you resurrected the thread I have to ask - (8) 55W halogen bulbs in the scanner??? WTF?
A single high-brightness LED in each would be enough.
Between the 55 watt scanning lights and all the other lights required for a KITT replica , yea I'll bet you do need an electrical upgrade and anything that can get the amps up while it's idling would be a very good thing indeed Thread Starter
its the reason I don’t often use the scanner. There’s enough going on with the dash!!
Car: 1984 Firebird Trans am
Engine: 5.0 HO 4BBl
Transmission: one that kind of works
Axle/Gears: some that turn the wheels
I'm bumping this thread again.
I'm curious what your solution was. I have a knight rider(ish) in that I just have the nose and the scanner bar. My problem is that I have a Taurus fan which pulls 40A and there is a noticeable hit to the car when it turns on. I have read that a 140A or 200A alternator would make a big difference. Any thoughts?
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I had one of these https://alternatorparts.com/cs144-se...ternators.html
Problem with the CS133 is the small bearings in it, the 144s had bigger/better bearings
Engine: 5.0 HO 4BBl
which one did you get? Are they a direct bolt in? 250A?
Car: 92 Firebird
Engine: 4.8 LR4
Call them and talk to someone. I originally was going to get a CS130 from them, but they convinced me not to because of the bearings. I told them what I had and what I wanted and they got me the right front and rear housings with the best clocking.
