MAF Sensor Cleaning - Camaro
Old May 7, 2017 | 01:42 PM
RocNRoll's Avatar
Car: 1988 IROC-Z
Axle/Gears: 3.08 POSI Rear
I have an 88 IROC 5.0 TPI that needs the MAF sensor cleaned. It has a screen on either side and I can't remove the housing from the Y shaped air intake. The MAF sensor housing has 4 phillips screws that I removed to try and get access to the sensor but can't get it to open.
Any suggestions on how I should proceed with cleaning it?
Old May 7, 2017 | 01:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: MAF Sensor Cleaning - Camaro
Don't remove the cover you can clean the element with maf spray through the center of the maf.
XrayTedd
Apr 4, 2017 02:45 PM
ItalianZ32
Feb 28, 2017 11:01 AM
SecondOwner
Feb 23, 2017 04:36 AM
