Hairline crack by thermostat - Any hope in fixing it?
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Hey guys, I replaced my thermostat on the top of my lower intake manifold awhile back, and I ended up tightening it down snug enough to the point I made a hairline crack I didn't even need to replace the thermo but there's nothing I can do now
It'll hiss out coolant when the engine warms up, and I don't want to drive the car like this. Is there any way/suggestions as to how I can fix this crack? I'd rather not have to swap the entire lower intake manifold if not necessary
Thanks in advance guys
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Re: Hairline crack by thermostat - Any hope in fixing it?
Hi there,
You might try JB Weld. It would be tricky doing it without removing the intake, but if you have a flexible finger, you might smear some inside there. Can't say how long it would last (if any) or if it will hold under pressure. Might be worth a shot before removing/replacing the intake.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
All great advice guys, many thanks
I took pictures but completely forgot to upload them here! The crack's a bit hard to see but it's there, I was wrong about this being the thermostat as it's actually the coolant temp sensor
Here's some pics-
Here's some pics-
