86 2.8mpfi 140k mi compression check/results
Want a title? Post!
Car: 1986 Pontiac Firebird
Engine: 2.8 MPFI
Last time i logged in was 2k13...crazy.
Top of the mornin' to ya, rest of it to me.
Short story long- been driving this beast for 2 years without the guage fuse in.
I might get into why later, cuz its a great story in itself, but car started dying, like a fuel starve. Noticed fuel pump stopped priming at turn key. Checked pressure @ rail like a true...shade tree mechanic. Squirt was non impressive. Autozone rented their fp guage to some dip that never brought it back yet.
Changed filter and checked squirt, much better. Still dying while hot and denied a restart for 5 mins to 6hours- crap shoot.
Anyways, decided to check compression, cuz really, with no guages and a loud stereo, who knows whats going on under the hood.
Results
(front pass to rear)
Cyl 1 120
Cyl 3 140
Cyl 5 110
(front driver to rear)
Cyl 2 135
Cyl 4 150
Cyl 6 150
All dry tested, cold engine numbers.
Since 2004 when i got the damn thing, pump primed on turn key. Now since it started dying, and being rediculous, pump primes on turning key OFF.
Idk. Are my numbers ok? Ill elaborate on the guages thing later. Possibly be a sober type story, so it all comes out in English.
Results
Cyl 1 120
Cyl 3 140
Cyl 5 110
Cyl 2 135
Cyl 4 150
Cyl 6 150
Car: 1998 Camaro Z28
Engine: 6.0L
Re: 86 2.8mpfi 140k mi compression check/results
Little variation and 2&6 seem a bit low on the passenger side. You usually don't want more than about 20psi variation between the cylinders.
Try doing it with a warm engine, you'll get more accurate readings. When your engine is cold, your numbers will be off since your pistons have not expanded and everything (including your rings) are moving around causing a less consistent seal. If you're still getting low numbers on the pass side, then shoot some oil in there and see if they come up or not.
84transamdude
May 17, 2012 05:41 PM
89 Iroc Z
Nov 17, 2001 03:52 PM
