Cam i do it or no
Old Jul 28, 2017 | 12:04 PM
Pzbos86's Avatar
Cam i do it or no
New remanufactured motor 3.1
Is there a larger cam i can put i where i wouldnt have to change everything
Old Jul 28, 2017 | 12:32 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Re: Cam i do it or no
the comp 260h is a safe bet. call up engle or crower or isky for more options.
Old Jul 31, 2017 | 05:59 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Melling MTC-5 is also an option, a lot cheaper one too.
Old Jul 31, 2017 | 08:58 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
A better option in my opinion is call Delta cams and get a 260 grind for about a 120 bucks shipped to the door It also will come with a lifter kit. You can run that Cam on stock Springs and stock valve train .
Old Jul 31, 2017 | 09:51 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
how radical can you go on the stock tune?
Old Jul 31, 2017 | 10:53 AM
fasteddi's Avatar
Car: 1991 Camaro RS
With the stock tune i wouldnt go bigger then a 260 cam. While you are in there you should really port the heads out a bit. Exapecially the valve bowls.
