my 91 camaro rs v6 tachometer goes straight past redline when started up
Old Feb 21, 2018 | 08:05 AM
91camaroRS2000's Avatar
Want a title? Post!
when you start the car, the tach goes straight past redline and stays there the entre time, the gauge was replaced once to see if it fixed the problem, but the new gauge did the same thing. it is a v6 3.1 litre. ive heard it could be the signal wire or some type of sensor, or maybe even a bad resistor. im a senior in highschool in automotive class just looking for some extra help, any thoughts?
Old Feb 21, 2018 | 10:43 AM
mrontime's Avatar
Car: 1991 RS 305 tbi
Engine: 305 tbi
Axle/Gears: one wheel wonder
Re: my 91 camaro rs v6 tachometer goes straight past redline when started up
there is a resistor chip in the guage cluster that costs about 90 bucks on ebay and will fix the tach. if you search for tachs for your 91 it will pop up in ebay. i just replaced mine with a pro comp tach instead
Old Feb 21, 2018 | 10:45 AM
mrontime's Avatar
Engine: 305 tbi
the signal wire is fine, otherwise it wouldnt bottom out, it would stay at zero
Old Feb 21, 2018 | 10:59 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/inte...w-90-92-v.html
Old Feb 22, 2018 | 09:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is a thread here on the Electronics board that covers replacing the bad resistor on the tach driver board. If you can do some soldering it is an easy fix. Check the stickies (threads up top) in the Electronics forum for the thread.
RBob.
Old Feb 22, 2018 | 02:21 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/elec...meter-fix.html
94Camaro
Jan 26, 2006 08:21 PM
