auxiliary Fan wont kick on
so i replaced my Aux fan because my orginal fan cracked. i replaced the coolant temperature sensor. Wired correctly. Cleared codes. Fuses re all good. I Don't know what it could be. anyone with info on how to fix greetly appreciated. Only thing i can think of the wiring between the temp sensor and fan is bunk.
Car: 1998 Camaro Z28
Engine: 6.0L
Re: auxiliary Fan wont kick on
Are you sure it worked before? If you take a paperclip and stick it in the A/B terminals of the connector under the dash (top row, furthest right two terminals), that will turn on the fan, you'll at least know if it functions correctly.
85-87IROC-LB9s
Oct 14, 2012 07:49 PM
