V6 2.8 1989 Starting Issues in heat
Old Jun 20, 2018 | 04:26 PM
krismarsel1's Avatar
Engine: 2.8
Hey! I'm getting heat soak issues. Cars running fine until it gets hot out, then after a 20+ Min drive I find it hard to start again. No start, no clicks, just gauges max out and no start.
After reading some forums i've found that our Camaros have starting issues due to the exhaust being so close to the starter.
Do the Corvette starters work with the Stick Shift V6' as well? (ive read they work well)
Getting frustrated with my car. Rebuild engine from the head up, new suspension, new gas tank/fuel pump...drives amazing when its on, just getting it on now is a issue
Please help
Old Jun 20, 2018 | 08:06 PM
PaulyC's Avatar
Re: V6 2.8 1989 Starting Issues in heat
I cannot comment on the Corvette starter but if it is starter heat soak, and it sounds like it is, just wrap it with reflective insulation or install a heat shield. You could wrap the exhaust where it passes by as well if needed.
If you use a different starter it will do the same thing unless its significantly smaller or otherwise further from the exhaust in some fashion.
Old Jun 20, 2018 | 10:32 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Headers?
Old Jun 21, 2018 | 02:14 PM
Engine: 2.8
no, stock
Old Jun 21, 2018 | 02:44 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I dealt with this issue for quite a while. I tried a remote mounted ford starter solenoid but same thing. So I simply installed a push button starter switch. Fixed my problem.
Kitten Tooth
Dec 31, 2016 04:27 PM
CamaroBully
Aug 10, 2012 02:21 PM
syc0path
Oct 25, 2005 02:06 PM
speedingpenguin
May 25, 2005 09:45 AM
