Carburetor swap?
Old Aug 8, 2018 | 03:20 PM
Arodriguez32462's Avatar
Carburetor swap?
I have a 1989 Firebird 2.8L mpfi and wanna know what would be need to be changed to swap it to a carburated version, I already have the intake.
Old Aug 9, 2018 | 09:15 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Carburetor swap?
You need a way to dial fuel pressure WAY down. You can get a 3 way fuel pressure regulator for that, look in the carb section, it's been covered before. I used one for my engine when I went to a carbed V8, it's a Mallory if memory serves me correctly. I assume you still want everything inside the vehicle to operate as normal, cluster and all so you'll have to modify the wiring harness. You'll also need a way for the fan to come on if you're keeping the electrical fan. It's been a little while since I did this so I'll have to think back to how I did mine.
Can I ask why you'd rather have a carbed 2.8 than fuel injected? It would seem to be a step backwards in regards to the lil bit of HP these engines already have.
Old Aug 9, 2018 | 09:48 AM
drdave88's Avatar
Engine: 6.0L
So if I remember right, I had my fan hooked up to a toggle switch. Bad thing about that is you have to remember to turn it on, I don't recommend it.
You can leave your sensor wires hooked up since they run to your cluster for your gauges.
I opted to open up the wire harness and strip out everything that I would no longer need. I relocated some relays and shortened some wiring.
I think you'll need a resistor wired in to the alternator for the "exciter" wire to let the alternator know to charge, since the PCM won't be doing it anymore.
The fuel pressure regulator is a Mallory 4309
You will need a different distributor since that is run through the PCM, which won't be there anymore. This will also involve more wiring if you want a functional tach.
New throttle cable and kickdown cable (if automatic)
I'm sure there's a lot I'm forgetting yet, but basically it's not "slap a carb and intake on and go".
Old Aug 9, 2018 | 12:37 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
What carb and intake do you want to swap? Factory CC carb of the holly carb with edelbrock intake?
GTAStockholm
Carburetors
Apr 16, 2012 12:46 PM
marine68
Carburetors
Apr 16, 2009 06:24 PM
FROZEN TUNDRA
Carburetors
Jun 10, 2007 04:51 PM
FROZEN TUNDRA
Jun 10, 2007 04:50 PM
KED85
Jun 25, 2002 10:56 PM
