Lost power?
Old Sep 27, 2018 | 05:40 PM
Stevenmunoz's Avatar
Car: 1987 Firebird
Engine: 2.8L V6
Lost power?
So I replaced by distributor and now I’ve lost a ton of power and of this time correctly. It feels sluggish but can drive normal speeds. It feels like the rpm climb is slower than before aswell. Going up slight inclines at nearly 2300rpm and it’s loosing speed whilst before it would climb at that rpm. I’m very confused maybe a kind of “Limp” mode? I haven’t a clue as to why it’s like this! Please help asap!
Old Sep 28, 2018 | 07:17 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Lost power?
If you replaced the distributor and now you have a loss of power, check for plug wires to connected properly and double check timing. It sounds like you didn't get timing set right though. Did you disconnect the EST wire, let the engine warm up and then set timing to 10 degrees at proper idle?
Old Sep 28, 2018 | 10:33 AM
Car: 1987 Firebird
Engine: 2.8L V6
Re: Lost power?
After I got it running I brought it to a shop for them to double check the timing and they said I was timed correctly. I just looked up a few things about that wire you mentioned and I did not do that so I’m going to warm my car up unplug the wires plug them back in and disconnect the battery and see if that helps I
Old Sep 28, 2018 | 10:59 AM
drdave88's Avatar
Engine: 6.0L
Re: Lost power?
Did they do it correctly? lol Why did you replace the distributor? Were you having issues like this before?
Old Sep 28, 2018 | 11:02 AM
Car: 1987 Firebird
Engine: 2.8L V6
Re: Lost power?
I believe so, and because the distributor cap screws were snapped off inside by the previous owner and the connections looked sketchy I just finished unplugging that wire and plugging it back in the battery after going through the process so I’m a take it for test drive and I’ll be back
Old Sep 28, 2018 | 02:53 PM
Car: 1987 Firebird
Engine: 2.8L V6
Re: Lost power?
It still feels more sluggish than before I replaced the distributor. I haven’t a clue why
Old Sep 28, 2018 | 03:54 PM
Car: 1987 Firebird
Engine: 2.8L V6
Re: Lost power?
Maybe old coil with new distributor? I checked my tps and maf and they aren’t the problem
hotrod9168
Jun 12, 2012 08:18 PM
84KYSS
Jul 4, 2008 09:15 AM
tbfirebird
May 6, 2003 06:47 AM
Coop89RS
Jun 9, 2002 03:54 PM
