Very sluggish 1983 2.8L S10 4x4 (freshly rebuilt)
Old Oct 6, 2018 | 09:20 AM
Turbo4271's Avatar
Car: 1983 Chevy S10 4x4
Engine: 2.8L V6
Transmission: 5spd WCT5
Axle/Gears: 411
Newly rebuilt engine. New Pistons, heads, Edelbrock 3790 cam kit, timing gears & chain, distributor, carb. Rings & bearings, and headers.
Did proper break in, and drove it about 2mi.
It took for ever to get up to 55mph and it acts like it won't go any faster. Had more pickup before rebuild when only running on 5 cylinders. Initial valve adjustment on engine stand was "0" lash then 1/2 turn more as per Edelbrock instructions. Timing at 8 before TDC.
Starts right up, and idles smoothly without touching accelerator. What are your thoughts on not enough lifter preload?
Old Oct 6, 2018 | 09:27 AM
Turbo4271's Avatar
Engine: 2.8L V6
Axle/Gears: 411
Re: Very sluggish 1983 2.8L S10 4x4 (freshly rebuilt)
Sorry guys & girls i didn't realize this was a Camero forum.
Although some Cameros came with the very same engine.
Any help would still be appreciated.
thanks
Old Oct 8, 2018 | 05:45 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I'd assume it's the same, but on the F bodys the base timing is 10 degrees BTDC. I'd try adjusting the timing somewhere between 10-12.
Old Oct 8, 2018 | 06:35 AM
Turbo4271's Avatar
Engine: 2.8L V6
Axle/Gears: 411
I'll try that
thanks
Old Oct 9, 2018 | 08:58 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
what break in oil did you use?
Old Oct 9, 2018 | 09:18 AM
Turbo4271's Avatar
Engine: 2.8L V6
Axle/Gears: 411
Cam2 10/w30 plus Lucas oil stabilizer
Old Oct 9, 2018 | 10:27 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
hopefully it has high zinc like these flat tappets need.
Old Oct 9, 2018 | 10:45 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Camaro, not Camero
Old Oct 9, 2018 | 10:50 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Originally Posted by scooter
Camaro, not Camero
yeah i see it spelled in for sale ads incorrectly more often than correctly.
Old Oct 9, 2018 | 12:33 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Me too, still doesn't make it right, lol
Old Oct 9, 2018 | 01:22 PM
drdave88's Avatar
Engine: 6.0L
Good point, I found that out the hard way before I swapped my cam in my 3.4, that oils didn't come with that anymore. It's not really a well known thing unless you're up on your oils.
Old Oct 9, 2018 | 03:54 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
yes, and many of those who are up on it still think rotella has enough zinc in it but it doesn't anymore.
Old Oct 19, 2018 | 02:03 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Would love to help but I don't know anything about the carb set up lol how's the carb set ? Fuel pressure and metering, and how the advance on the dizzy is so controlled ? Vacuum ?
Old Oct 22, 2018 | 06:48 AM
Turbo4271's Avatar
Engine: 2.8L V6
Axle/Gears: 411
The carb is a Reman. 2bbl verajet, new mechanical fuel pump, (5-7psi)? Vacuum advance dist,
readjusted valve lash ( 1-1/2 turns after "0" lash) engine perked up some, but not where it should be.
thanks.
Old Oct 22, 2018 | 08:43 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
You can check the cam from the pushrod rocker movement, just in case . I'd check the comp ratio ? After a rebuild ? Def bump the timing maybe the dizzy isn't acting how it should ? Just some ideas.
Old Oct 23, 2018 | 07:15 AM
Turbo4271's Avatar
Engine: 2.8L V6
Axle/Gears: 411
Will do, I'll try that
lakeffect2
34
May 30, 2017 10:55 PM
gcj280
Apr 25, 2017 04:43 PM
iroc-yow
Nov 13, 2016 11:21 AM
lasher454
Aftermarket Product Review
Jun 27, 2001 06:13 PM
82camarov6
Nov 13, 2000 02:58 PM
