TPS disconnected, no more stall?
Old Dec 9, 2018 | 04:14 PM
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
Hi guys, may be my stalling problem was about the TPS? Whir warm engine, I disconnected the IAC first, no changes. When I disconnected and reconnected the TPS, the engine gradually got better, with no more stalling problem! I noticed the path of the alternator, IAC and TPS wiring harness: is that normal that the harness is so close to the thermostat hose? This should explain the stalling problem when hot? Any help is very appreciated!
Thanks!
Old Dec 25, 2018 | 10:53 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: TPS disconnected, no more stall?
I'd have to check .It is all very tight around there though, that position shouldn't be causing any problems , all the wiring is designed to handle engine bay heat . Unless it's rubbed worn out and grounding .
Old Dec 25, 2018 | 10:55 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
I'd guess you just have some corrosion on the connection, that you cleaned when you disconnected and reconnected the plug , get some cleaner spray in there, carefully with a small file / knife clean it up , or push it on off a few times to clean it up .
Old Dec 26, 2018 | 12:04 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I don't think tps would cause a stall. When I rebuilt my trans, freshened up my 3.1 and put everything back together I was stalling when coming to a stop. The grounds on the back of the heads were a bit loose. Might wanna check those if the new tps doesn't fix the issue.
Dean_GTA
Oct 23, 2009 01:46 PM
Dean_GTA
Apr 5, 2009 02:53 PM
SatisTraction
Oct 19, 2007 11:04 PM
voltran
Dec 5, 2000 05:34 PM
