Hybrid
Old May 8, 2019 | 12:52 PM
Arodriguez32462's Avatar
Hybrid
I have an 89 2.8l and also have a 3400 long block, from what I understand a head swap can be done? I'm a little confused on what all I need for it, can someone clarify?
Old May 9, 2019 | 05:53 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Hybrid
There's a ton of threads on this, as well as a sticky at the top. Long story short though, most people will take the 3.4 RWD block and swap a 3400 FWD top end on to that. You can't use a 3400 block in a RWD car. There is more to it though, read the sticky and then search on 3.4/3400 hybrid and you'll find what you need to know. I think someone was working on a 2.8/3400 hybrid a while back, maybe search on that one too. You'll need to be able to fabricate some parts, I think a crank sensor mount, throttle cable bracket, some others. It's been a long time since I last looked into it.
fattie92
Jul 27, 2002 02:43 PM
tpi_roc
May 4, 2002 07:30 PM
MIG-29
Feb 25, 2002 09:39 PM
kevin-design
Mar 7, 2001 08:52 AM
