Vacuum Lines and Boost
Old May 28, 2019 | 02:52 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
On Project89's old thread, he said "the only one mod i had to do was install a check valve on the heater control valve line, the line that controls the vents, without on it would pop the hoses off, its like a 79 cent part form the auto parts store". can someone show me what piece he put in, and where?
Old Aug 13, 2019 | 07:44 PM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
Re: Vacuum Lines and Boost
A one way check valve. Also you can use fish tank one way valves. We used to use those to trick boost reference on maps in the early days.
Anyways. It should be installed on the back of the intake mani. There is a line that goes through the wiring harness I believe ( been years, I don't have any now). You want vacuum open under vacuum. Also if using the fish tank type, oil them up. WD-40 or whatever. They work better that way. And the they part is you may need more then one.
Pilotrick50
Nov 26, 2015 10:20 PM
jfelte
Carburetors
May 3, 2011 06:48 PM
Code1racing
May 8, 2010 09:38 PM
Stevo
Jul 23, 2007 05:48 PM
