2.8 MPI Camaro engine bolts
Old Jul 25, 2019 | 12:05 PM
Brokeboy's Avatar
I recently purchased a 1986 Camaro SC with a 2.8 MPI engine. The problem is that the kid who had it had started to replace parts like the water pump and alternator and LOST THE BOLTS FOR THE PLENUM AND EVERYTHING ELSE ON TOP OF THE ENGINE.
i have been trying to locate a source to replace the bolts but I am not having any luck. Any help at this point would be greatly appreciated.
Old Jul 26, 2019 | 06:03 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: 2.8 MPI Camaro engine bolts
I don't know of a bolt kit to buy for these. You may want to check junk yards around, see if you can find any of the bolts you need off a car out there.
Old Jul 26, 2019 | 09:41 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Most can be replaced using hardware store (or bolt fastener store) sourced bolts.
Only a few that come to mind that you will likely need to hit up a wrecking yard for, and those are some of the water pump bolts, since they are usually longer than what is commonly available.
88firebirdguy
Feb 15, 2020 04:50 PM
madmurk88
Jun 2, 2011 10:08 PM
Kamaros
Exterior Parts for Sale
Aug 5, 2010 09:14 PM
Darkshot
Aug 5, 2009 07:35 PM
scanman717
May 10, 2004 01:45 PM
