Air Pump Check Valve (Also called A.I.R. something)
Old Jan 11, 2002 | 01:52 PM
Setzer's Avatar
Have any of you replaced this part or even know what I am talking about? At the end of the piece there is a part that a tube should fit on, do any of you know where this tube connects to? Also, there is a note that came with the new Air Pump Check Valve that says before replacing your air pump valve, verify the operation of the air management/diverter valve. What in the name is that, where do I find it? I think I have heard of it before but cant remember really. Any help would be awesome. Thanks
~Josh~
Old Jan 11, 2002 | 08:59 PM
Camaro_hunter_d's Avatar
ok.. looking at the tube that comes up from the 'Verter, you will see a Black part about 4 inches long that has a large (2") diameter circle/disk type looking thing twoards the front of the car. It has a rubber hose conected to the front that does a 90 deg turn downward. This is the One way Check valve. The rubber line/hose goes down to the air pump output tube. The Dirverter Valve is built into the valve system on the back of the air pump. I do not know if you can take it off or not, I believe you can though. BUT you can get a new air pump for HALF the price of the Diverter Valve.
Old Jan 11, 2002 | 10:25 PM
Setzer's Avatar
Hey thanks for the info I will try that tomorrow. When you say 'Verter do you mean Cat Converter?
~Josh~
Old Jan 13, 2002 | 01:03 PM
yes
Old Jan 13, 2002 | 07:58 PM
Setzer's Avatar
Infested
May 22, 2018 11:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
TreDeClaw
Aug 14, 2015 06:58 PM
mcquigg
Aug 13, 2015 02:26 PM
