Repair Manuals
Old Aug 13, 2019 | 04:53 PM
Brokeboy's Avatar
Repair Manuals
What is the best repair manual for a 1986 Sc with MPFI?
Old Aug 13, 2019 | 05:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Repair Manuals
Helm you can posted in the classifieds wanted section or look on eBay.
Old Aug 13, 2019 | 05:44 PM
Engine: Lb9
Transmission: M20
Re: Repair Manuals
https://www.ebay.com/itm/1986-CHEVRO...QAAOSwFpNdCT0l
Old Aug 13, 2019 | 05:49 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Repair Manuals
Well that depends on what you're looking to do. Haynes and Chiltion Manuals are always a good bet for mechanical, but if you're looking for body info there are a couple on that subject too. A simple google or eBay search should provide you with the info you're looking for. There are a lot of paper options as well as downloadable manuals.
Old Aug 13, 2019 | 07:46 PM
Brokeboy's Avatar
Re: Repair Manuals
I purchased the 86 SC from someone who had started to tear down the engine. I need to be able to tell where things go when I am putting it back together. Things like the coil pack and bracket. I have tried to find pics but none show that. He had removed the throttle body and plenum and lost the bolts.
Old Aug 14, 2019 | 08:26 PM
jharrison5's Avatar
Car: '87 IROC
Re: Repair Manuals
There are three books put out by GM that will cover everything you need. First is the bible of books the "Parts and Accessories Catalog" which was supplied to dealerships and contains all of the diagrams and part numbers for our cars. They are really hard to find in book from though, but I believe you can find them in a digital format. If you're able to locate one look for the 1982-92 version since it will be the most complete.
Second are the "Service Manual Supplement" books that were put out for each year of the camaro and Firebird. These can be easily found on Ebay as books or Digital format.
Last is the "Body Assembly" Manual for you specific year. These can also be found online in book and digital format.
I also recommend getting a Haynes and Chilton Manual.
If you can find copies of these books it will give you all of the info you could ever want on our cars.
Old Aug 15, 2019 | 07:27 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Repair Manuals
Find an original Helm Factory Shop manual; they're out there, but you'll have to dig to find one. Aftermarket manuals don't provide anywhere near the amount of info or diagrams that the factory item provides, and can't be trusted regarding specs, especially where wiring diagram accuracy and color coding is concerned.
I bought mine right after I bought my '86 IROC new back in '86; IIRC, it cost a little over $80.00 at the time (expensive, yes, but worth every cent, especially today).
Old Aug 15, 2019 | 09:23 PM
Brokeboy's Avatar
Re: Repair Manuals
Thank You!l
Old Aug 15, 2019 | 10:00 PM
jharrison5's Avatar
Car: '87 IROC
Re: Repair Manuals
Thank You!l
This forum is a wealth of knowledge so make sure you utilize the search feature, because I know I have hundreds of times!
racing geek
Jan 6, 2009 08:10 AM
RAV3N
May 26, 2005 10:03 PM
tom3
Sep 15, 2004 01:33 PM
yankeecarman
Mar 11, 2003 05:14 PM
rhyners
Jan 22, 2002 01:26 AM
