Valve stem seals...
Old Nov 18, 2019 | 02:13 PM
Iroc95's Avatar
Car: Camaro rs 1991, BMW e39, F11
Engine: V6 3.1
Transmission: 5 speed manual
Axle/Gears: Stock
Valve stem seals...
Hello, I need to repleace valve stem seals on my 3.1 v6 1991
In the kit I got 6 positive seals and 12 o-rings.
I`m confused because I got 12 o-rings, old o-rings were destroyed and felt apart while removing the springs.
I know that positive seals were on the intake valves and o-ring seals on the exhaust valves, but not sure if o-rings were also on intake valves.
So I need to put positive seals on intake valves, o-rings on exhaust valves, but do I also need to put o-rings on intake valves?
Thank you for help
Old Nov 21, 2019 | 09:51 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Valve stem seals...
I've always just installed positive seals on both intake and exhaust valves, never bothered with the O rings. They seal better anyway. That's what most do on here too, if you do a search.
Old Nov 26, 2019 | 02:40 PM
Iroc95's Avatar
Engine: V6 3.1
Axle/Gears: Stock
Did positive on intakes and orings on every valve. Installed the head yesterday, doing timing chain today
Thank you for help
gta88 flamered
Mar 6, 2016 06:49 PM
gtaproject
Oct 20, 2008 06:13 PM
IRACE87
Sep 12, 2005 06:27 PM
drdave88
Dec 23, 2003 03:52 PM
grndmasnightmar
Nov 13, 2003 05:00 PM
