Heater Core??
Old Jan 13, 2002 | 07:36 PM
85CamaroRulz's Avatar
Heater Core??
My car started blowing anti freeze up on my windshield and fogging it up from the vents and anti freeze was dripping from beneath the dashboard on the passenger side? What is this?
Old Jan 13, 2002 | 09:28 PM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
Sounds like the heater core, or maybe one of the lines that go to and from it. When mine went, I smelled coolant and saw it dripping around where the vents are under the radio.
Old Jan 13, 2002 | 09:53 PM
I Cant Drive 55's Avatar
Sounds like heater core to me too. They are a pain to change.
Pick a day you have nothing else to do, it took me about 5 hours to change mine and I do mechanic work all the time.
Old Jan 13, 2002 | 10:14 PM
KED85's Avatar
Heater core.
No, stop leak doesn't work well at all!
I tired that too.
AND DON'T BOTHER REPAIRING THAT HEATER CORE.
You buy NEW
Or just bypass core & live without heat.
But, be aware, the longer you drive with core that bad, it may explode and all coolant leaks inside car & you are stranded.
Bypass it is quick cold fix.
Old Jan 14, 2002 | 12:44 AM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Yeah..to replace it effectively, it's reccomended you disassemble a good portion of your dash...I reccomend picking up a Haynes/Chilton's repair manual for this...it's not hard, but it's a pain in the *** process.
Old Jan 14, 2002 | 02:31 AM
Camaro_hunter_d's Avatar
I have replaced them in 90-92 camaro 2-3 times and it was not hard. Just alot of repetive small nuts-bolts-screws. and alot of plastic to move to get to it.
Old Jan 14, 2002 | 09:41 AM
Engine: 2.8, LS1
Had a mechanic do mine Took 'em the better part of a say too! Not to mention they spilled coolant all over my passenger side,,,,
Old Jan 14, 2002 | 01:14 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I plan on doing mine this spring, just for $hits and giggles, before it breaks on me. After all, I just got new carpet two years ago!
ndndndnd
Sep 28, 2015 08:00 AM
Formula8r89
Sep 22, 2015 04:24 PM
