A.I.R. System check valve
Old Mar 23, 2020 | 08:46 AM
luca's Avatar
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
so i heard a strange kind of gurgling sound out of the engine bay when the engine is cold or hot, i removed the air pump and
noticed that the air check valve makes this sound .
it pulls air past the valve in the exhaust manifold i bought a new check valve but it was better with the old one
is this normal ?
https://files.fm/u/p649qmzf#/
THANKS
Old Mar 23, 2020 | 10:06 AM
Drew's Avatar
Re: A.I.R. System check valve
Cheap Chinese Beer Flu garbage. Try a used GM part.
Old Mar 23, 2020 | 11:31 AM
luca's Avatar
Car: Firebird
Engine: 3.1
could be
the brand is Standard
i did test it with the factory one sounds better
but it seems not right to me
it sucks air into the exhaust not exhaust though the valve
Old Mar 23, 2020 | 12:56 PM
Drew's Avatar
The valve is supposed to keep the exhaust from flowing back into the air system when the air is diverted to atmosphere. You can take the valve off and screw a pipe cap on, and aside from emissions going up a touch, it'll run the same with no noise.
Old Mar 23, 2020 | 01:19 PM
luca's Avatar
Car: Firebird
Engine: 3.1
unable to bypass emission related stuff where i live
i can not believe that the check valve should pass air like this into manifold ( i think i should have a little resistance that the air pump has to overcome when the
air control valve at the backside of the pump opens.
all so the car runs too rich but only at idle
Old Mar 23, 2020 | 01:36 PM
Drew's Avatar
It's just a 1-way valve. Air should flow in freely, exhaust shouldn't flow out. The air pump doesn't generate much pressure. A lot of the air hoses aren't even clamped.
SaxophoMan
May 6, 2016 08:28 AM
TekViper
Aug 18, 2003 10:22 AM
TekViper
Aug 14, 2003 06:20 PM
Neo
Feb 12, 2001 11:05 PM
