engine idles very rough
Old Jan 13, 2002 | 07:58 PM
Hank Hill's Avatar
engine idles very rough and has some smoke. Any suggestions on possible fixes
It is a 87 with a 2.8. thanks
Old Jan 13, 2002 | 10:08 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Where is TomP...
Well, If I were TomP, which I am not, I would ask you when was the last time your car recieved a complete tune-up?
If its been a while then check out this page. https://www.thirdgen.org/techbb2/sho...t=Major+Tuneup
Now I would say to try and tame down the rough idle buy checking your timing and see if it is set correctly. Then check for vacuum leaks.
The black smoke; I had my front crank seal go, it was $12 to replace and an hour of my time.
When it went it sprayed oil all over the exhaust, so I would see black smoke.
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Bradsaundry
Aug 12, 2015 12:34 AM
