3.1L CCV Replacement?
Old Apr 23, 2020 | 03:02 PM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LH0
Transmission: Tremec TKX
Axle/Gears: 3.23 Torsen
I think I may have finally found my oil leak, but I'm having trouble finding the parts to fix it. I'm no expert, but according to all the diagrams online this is a CCV, but I'm struggling to find any place to get a new part for it. Is there a valve in there similar to a PCV? It didn't pull out easily like a PCV would, so I decided not to yank on it and risk breaking something, since I'm still fairly new to working on cars. Any tips for fixing that leak/ replacing that bit would be much appreciated!!
Old Apr 23, 2020 | 03:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 3.1L CCV Replacement?
Are you referring to the crank case breather ?
you might see what Dorman offers.
Old Apr 23, 2020 | 03:19 PM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LH0
Maybe? Like I said, I'm new to working on cars, I'm not sure of what exactly to call it. It's the tube that goes from the passenger side valve cover to the air intake, just before the plenum. Specifically, the issue is that oil is coming out from under the bit that's attached to the valve cover.
Old Apr 23, 2020 | 03:33 PM
Engine: Lb9
Transmission: M20
Old Apr 23, 2020 | 03:35 PM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LH0
Solid, thanks! Didn't think that it'd be under PCV, but I suppose I should have checked into that before posting Thank you!!
southbaysd
May 30, 2015 08:34 PM
Stevo
Sep 8, 2005 03:37 PM
DeathZ
Pacific Northwest Region
Jul 21, 2001 03:46 AM
AmorgetRS
Jul 18, 2001 01:22 AM
Kevin S
Mar 30, 2001 10:37 AM
