car damaged getting off trailer
Old Jul 28, 2020 | 07:55 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
So last weekend i was moving and got to my new place and proceded to unload my car. few hours later i had it off and torn up.
ripped the exhaust off at the y pipe and something broke in the trans. its a 5 speed. best way to go about troubleshooting the transmission with out removing it? its also stuck in a forward gear.. probably. the shifter moves funky so i know its screwed up. tore up the trailer getting the car off also.. not happy camper. more things to fix..have to fix my car so i can drive it. truck needs work and i don't want both vehicals down. i would rather not drop the trans out. last time it was out was 2008. when i replaced the engine and i have a new clutch for it if need be.
Old Jul 29, 2020 | 08:17 AM
RKeats's Avatar
Engine: 5L TPI
Transmission: WCT5
Re: car damaged getting off trailer
Was this a liquor fueled adventure? How do you go about mangling the car that bad from just taking it off a trailer
Old Jul 29, 2020 | 01:20 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Yeah I've been guilty of doing the same thing after a few adult beverages...
Old Jul 29, 2020 | 07:53 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
no beverages involved. got high centered getting off trailer and the rear edge of the trailer got ripped up and caught under the car. ended up dragging the car off the trailer with my truck since it was stuck so bad. probably didn't help. the main problem is the car is stuck in gear and can't shift it out of gear. shifter moves but its not changing gears.
Old Jul 29, 2020 | 09:51 PM
jharrison5's Avatar
Car: '87 IROC
Ouch it hurts more when you do it while sober...
OK so before we start pulling the trans out I would start with looking to see if the shifter is actually engaging with the transmission. Pull out the console, pull back the carpet, remove the rubber shifter boot, and then pull out the stick itself to see if somehow the ball popped out of the socket or is broke. If it is then that will be an easy fix and if not you're probably going to have to pull the trans because you either have it bound up somehow from pulling it, or you broke a shift fork, gear, or something else internally.
Old Jul 31, 2020 | 06:30 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
i hope its an easy fix. knowing my luck probably not.
DirtySpleen
May 21, 2013 08:24 AM
//<86TA>\\
Sep 3, 2007 02:26 PM
LG4TA
Jan 12, 2003 08:25 PM
CrashedMatrix
Dec 13, 2002 09:31 PM
bhaas
Jun 22, 2001 08:58 AM
