Throttle body/FPR lines
Old Aug 25, 2020 | 03:41 PM
86Lucille's Avatar
Car is cranking but fuel is shooting out. Where does this piece go?
Old Aug 25, 2020 | 03:43 PM
86Lucille's Avatar
Re: Throttle body/FPR lines
I already used the search bar.
Old Aug 25, 2020 | 05:56 PM
86Lucille's Avatar
It’s the line coming from the throttle body and fuel pressure regulator.
Old Aug 25, 2020 | 06:07 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
sounds like your diaphragm in the regulator has a hole in it
Old Aug 25, 2020 | 06:14 PM
86Lucille's Avatar
If I were to replace the regulator, where would the line go? I heard something about an air diverter or air management valve that’s supposedly on top of the air pump but I can’t find it for the life of me.
86Lucille's Avatar
I’m assuming there shouldn’t be fuel going through it too?
Old Aug 25, 2020 | 06:18 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
the fuel should only be going threw the metal lines to the injector block to feed the injectors. definitely not from a vacume line
Old Aug 25, 2020 | 06:28 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
you can see the fuel and return lines only go to and from the block feeding the injectors
Old Aug 25, 2020 | 06:43 PM
86Lucille's Avatar
Ok, so the fuel lines are the only wants that should be shooting fuel. Since there’s fuel in the vacuum line coming from the regulator, you mentioned there’s a hole in the diaphragm. That should be replaced. I’m guessing this is the reason it won’t start since it’s not getting the appropriate fuel pressure. What about the vacuum leak? Should I plug it? I don’t know where it goes. I should be able to get the new regulator sometime around Thurs and i’ll have time around Mon to install it, so hopefully it won’t rot in the backyard anymore haha.
Old Aug 29, 2020 | 09:57 PM
Mark RWC's Avatar
The fuel regulator uses engine vacuum. A vacuum hose attaches to the regulator housing. My guess is that is the hose that is not currently connected. See attached photo.
micktroup2
Feb 16, 2011 04:25 AM
TheSwarm666X
Dec 21, 2010 12:30 PM
chrisf2011
Oct 7, 2009 07:56 PM
mgray10
Jan 28, 2004 01:48 PM
