Help with vacuum lines
Old Feb 24, 2021 | 09:21 PM
Blaise Massey's Avatar
Car: 1990 Camaro RS
Engine: 3.1L V6
One
One of my vacuum lines from my fuel pressure regulator isn’t going anywhere, my diagram says that it goes to the air management valve but I can’t seem to find it, can anyone with a 3.1l V6 show me where it is?
Old Mar 13, 2021 | 06:56 AM
luca's Avatar
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
Re: Help with vacuum lines
its the magnetic valve bolted to the smog pump
it is directly under the alternator
best you remove the pully belt and the smog pump than you have easy access
there should be a a electrical connector as well
Jadelutis
May 1, 2020 06:54 PM
lcmchefslife
Aug 17, 2017 11:54 PM
Black89TransAm
Aug 20, 2006 04:40 PM
84_berly_84
May 27, 2004 05:59 PM
91zconv
Aug 23, 2003 08:06 AM
